vcStatisticsTab
vcStatisticsTab is an object representing a tab listed in a Statistics dashboard and contains one or more charts which are organized in a grid.
Referenced by: vcStatisticsDashboard.SelectedTab, vcStatisticsDashboard.createTab()
ChartslistRGets all the charts of tab.
LayoutslistRWGets or sets the available layouts for tab grid.
Each element in the list is a list with following content:
First element is String layoutName. Next elements are Lists, each of which contains info about a single tile or placeholder.
The tile info lists each contain these elements: String placeholder_name, Integer column, Integer row, Integer columnSpan, Integer rowSpan
ValueError: When the given list contains an invalid value.
MaxColumnsIntegerRGets the maximum number of columns in tab grid.
MaxRowsIntegerRGets the maximum number of rows in tab grid.
NameStringRWGets or sets the name of the tab.
SelectedChartvcStatisticsChartRWGets the active chart of tab.
SelectedLayoutobjectRDefines the attributes of SelectedLayout.
First element of the list is String layoutName. Next elements are Lists, each of which contains info about a single tile or placeholder.
The tile info lists each contain these elements: String placeholder_name, Integer column, Integer row, Integer columnSpan, Integer rowSpan.
SelectedLayoutIndexIntegerRWGets the index of the current layout of tab grid.
IndexError: When the given index is out of range.
clearLayoutNoneNoneDeletes all charts from tab grid.
createChartvcStatisticsChartvcStatisticsChart chartLocation,
vcChartType chartType,
Optional Keyword[activate = Boolean]
Creates and adds a new chart of a given type to tab grid.
chartLocation (vcStatisticsChart): Specifies where in the grid to insert the new chart. In this context, the vcStatisticsChart object is a grid location. It can be a chart with existing data or an empty chart used as a placeholder. In either case, a call will remove the existing chart and exchange it with a new one in the grid.
chartType (vcChartType): Type of the chart.
Optional: activate (Boolean): Specifies if the new chart is set as the active chart in tab.
vcStatisticsChart: The created chart.
createLayoutNoneNoneCreates a new layout for tab grid.
deleteNoneNoneDeletes this tab.
